SignalProcessing.UnwrapPhase vs. Unwrap Phase VI
I noticed that the SignalProcessing.UnwrapPhase method, according to documentation, "Unwraps the phase array by eliminating discontinuities whose absolute values exceed 2*Pi radians."  However, the Unwrap Phase VI in normal Lab View uses Pi, not 2*Pi.  Is this a mistake in documentation?  Is there another Measurement Studio method which mimics the VI?
Thanks!
(4,777 Views)
Accepted by MPLynch
MPLynch,
You are correct. There is disparity between the two functions and this is not a documentation mistake. However, this situation is easily rectified...
The forumula that is used for the UnwrapPhase in LabVIEW is
x[i] = x[i] - Floor((x[i] - x[i-1])/(2.0*Pi)+0.5)*(2.0*Pi), for each i in x
You can make a function that will mimic this formula and use that instead of the SignalProcessing.UnwrapPhase method if you need two to match.
Steven Zittrower
Applications Engineer
http://www.ni.com/support
(4,758 Views)
Thanks a lot for the help.
In case it wasn't blatantly obvious, I'm a bit new to the world of signal processing.  Really appreciate the nudge in the right direction.
(4,752 Views)
