Stepper motor control
We are using NI-USB multi function DAQ cards, NI-DAQmx and Measurement Studio.
A next project might be a closed loop control where we would like to control many stepper motors (max. 20). Is there any nice way to make the stepper motor controllers by C# and Visual Studio? Maybe I must make a wrapper around NI motion software library.. or something..?
What driver software we need? What new hardware?
The closed loop controller's cycle time is not critical;  a few hertz is OK..
BR,
Ilkka
(7,361 Views)
Hi, it depends which HW-Platform you want to use.
There are basically two possibilities.
1)  PCI- or PXI-Card programmed with NI-Motion --> C-API can be use in C#/C++-Projects
2)  NI-RIO based Softmotion System, programming with LabVIEW (FPGA) / System can be interfaced via C-API
for 20 axes you need a couple of Motion-Cards or a cRIO-Chassis + Expansion Chassis loaded with motion modules + the drives for 20 axes (depends on the power of the steppers)
Marco Brauner NIG
(7,353 Views)
speed control or position control?  what is your feedback mechanism?
Stu
(7,346 Views)
Hello Stu,
A simple position control is enough.
The feedback: We would like to balance and tune a big diesel engine. We are measuring cylinder pressures and some other parameters. Based on that we would like to mechanically push some parts affecting to fuel injection. A linear stepper motor accutuator is maybe a good solution for that..
The maximum twenty stepper motors is related to a cylinder count of the engine; one stepper motor per cylinder.
BR,
Ilkka
(7,332 Views)
i would solve this with a cRIO chassis and FPGA control of step and direction to stepper motor controller that can use step and direction input.  then implement a TCP/IP protocol to control/monitor it from C.  the pressure feedback could be incorporated into the cRIO as well.
one chassis, one digitital module, one analog module.
i have created this kind of application for stepper control several times.
Stu
(7,329 Views)
Yes.. thanks a lot. I will check the cRIO solution for driving the actuators. I found also an idea, that it is possible to make a communication link between the C#/.NET application and cRIO with a help of shared network variables.
I will surely make the feedback control algorithms into the existing C# application. It contains many years of work and I am not ready to transfer those into cRIO. (I have no experience of it :-)).
Have a nice day,
Ilkka
(7,326 Views)
