Synchronizing data through digital lines in c# with PCI 6221 (37 pin)
I'm developing  a software in c#, I'm working with PCI 6221 37 pin.
I want to be able to send data through digital lines,while the data is synchronized by a specific hertz rate.
In other words i need to send a data (an array of bytes) at the same time.
Can u advice me some solution.
Thanks for the help.
(4,270 Views)
Take a look at this:  http://forums.ni.com/ni/board/message?board.id=250&message.id=44644&requireLogin=False
h_baker
(4,242 Views)
Thank you for your reply.
But the examples provided doesn't explain how to do what i wanted to do.
I attach an image which shows what i was going for:
As you can see, I want the data to be sent via the lines in a specific rate that is set by me.
Hopefully this will help understand me better.
Thanks again.
(4,224 Views)
Have you looked at the example Cont Write Dig Port-Ext Clk?  The external clock will allow for you to control the rate.
h_baker
(4,197 Views)
