System.StackOverflowException occured in NationalInstruments.UI.dll
I'm using Windows XP SP3 with Visual Studio 2010 prof. SP1 and Measurement Studio 2012.
My Application run on my other PC without any Problems, now I changed on a new PC. If I load my Project in Visual Studio and start it, I get an Exception in the InitializeComponent-Method of my Form:
this.wfpSinus = new NationalInstruments.UI.WaveformPlot();
-> StackOverflowException was unhandled
An unhandled exception of type 'System.StackOverflowException' occurred in NationalInstruments.UI.dll
If I remove the WaveformPlot from my GUI the Program runns without any Problem. If add the WaveformPlot again, I have the same Problem again.
I also have LEDs and Switches on my GUI without any Problem. If I add a Tank, I have the same Problem like WaveformPlot.
(7,334 Views)
Hi Chris, does the exception also occur when you create a new WPF project from scratch?
(7,305 Views)
No!
I forgot to say: It's a WindowsForms-Project and no WPF!
But if I create a new project from scratch (WindowsForms), it works.
Why does my existing project doesn't work?
(7,301 Views)
Of what class is wfpSinus? What happens if you newly define it with the following?
NationalInstruments.UI.WaveformPlot wfpSinus;
(7,295 Views)
I think I don't know what you mean.
I have this situation:
private NationalInstruments.UI.WaveformPlot wfpSinus;
private void InitializeComponent()
the program throws an exception at "this.wfpSinus = new NationalInstruments.UI.WaveformPlot();"
If I delete the rows and rewrite the folowing code:
private NationalInstruments.UI.WaveformPlot wfpSinus1;
    this.wfpSinus1 = new NationalInstruments.UI.WaveformPlot();
 the program also throws an exception
(7,289 Views)
this.wfpSinus is an object. An object has a class and must come from somewhere. I would like to know if you are aware what class it has and where the object is created.
(7,285 Views)
Yes I know what class it has and where the object is created.
(7,271 Views)
