c# measurement
I use following timer counter analyzer.
Brand: Pendulum
Model: CNT-90 Incl. Option 30 Built in.
Firmware revision: V1.28
I develop c#.net application for communication with cnt-90 device.You can see below an example part of c# code for measurement.
        [DllImport("visa32.dll")]
        static extern int viOpenDefaultRM(out int rm);
        static extern int viOpen(int rm, string ResourceName, int viAccessMode, int TimeOut, out int vi);
        static extern int viClose(int vi);
        static extern int viRead(int vi, byte[] buffer, int count, out int retCount);
        static extern int viWrite(int vi, string buffer, int count, out int retCount);
public Measure_Frequency()
            byte[] Buffer = new byte[255];
            string Command = ":MEASure:FREQuency?";
            int status;
            status = viWrite(vi, Command, Command.Length, out RetCout);
            if (status != 0)
                error = "viWrite error!";
                return;
            status = viRead(vi, Buffer, 255, out RetCout);
            if (status != 0)
                error = "viRead error!";
                return;
    // received Buffer assessment procedures
I communicate with usb port for measurement with cnt-90.When I take a single measurement with our above Measure_Frequency function, there is no problem.But whenI take consecutive six sample measurement with our above Measure_Frequency function some values coming out of bounds.
I receive measurement data from the device with the above example.This is a correct method?
What are your suggestions in this regard?
Thanks in advance.
(6,373 Views)
Hi Liptolip
What is exactly what you want to do measure continuously or measure the frequency on the call of the function?
Have you check the C# examples that you should have in your PC when you install the DAQmx drivers here is a link with more information.
Text Based NI-DAQmx Data Acquisition Examples
Regards
Esteban R.
(6,342 Views)
