The following error occurred when I installed Measurement Studio 2019
I have installed Visual Studio 2015 on my computer.The following error occurred when I installed Measurement Studio 2019.It said:Packages with compatible versions and architectures could not be found.1569595176(1).png
(4,285 Views)
I've the same problem with Package Manager 19.5.0.
I've started a service request.
I'll let you know if I get a solution.
Johann
(4,186 Views)
Accepted by jyysns
It seems to be a problem of NI Package Manager 19.5.
I've uninstalled it and installed the older 19.0 Manager and it works fine.
Johann
(4,179 Views)
How were you able to use NI Package Manager 19.0?
I uninstalled NI Package Manager 19.5 and install NI Package Manager 19.0. When I tried to install Measurement Studio NI Package Manager 19.0 pushes to install NI Package Manager 19.5 without any option.
(4,156 Views)
I ran Package Manager 19.0 and select NI Measurement Studio 2019 ...
Maybe you've executed the Measurement Studio online installer first?
Hans
(4,129 Views)
I had  very similar issue. I upgraded from 2016 to 2019 and had to install the newer Measurement Studio. I did the following steps:
  1. I contacted support (very nice guys!) and they recommend to do a full uninstall and re-install. This did not work.
  2. Reading this i was planning on force reinstall measurement studio but first needed the entire file
    1. Downloaded the file from this as a "Individual Offline Installers" ~ 5 GB
    2. Mounted the ISO and ran the install.exe
    3. Step 2 solved the problem and I did not have to do a force re-install.
(3,703 Views)
