03-21-2012 03:51 PM
Hello:
I am developing a C#/.NET that uses DAQmx 9.4 to communicate with a NI 6015 DAQ Pad.
When I try to write to several digital channel lines at a time, an error message is returned:
var digitalWriteTask = new Task(); digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line0", string.Empty, ChannelLineGrouping.OneChannelForAllLines); digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line1", string.Empty, ChannelLineGrouping.OneChannelForAllLines); digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line2", string.Empty, ChannelLineGrouping.OneChannelForAllLines); var dataArray = new bool[3]; dataArray[0] = true; dataArray[1] = false; dataArray[2] = false; var writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream); writer.WriteSingleSampleMultiLine(true, dataArray); // The following error is returned when the writer.WriteSingleSampleMultiLine method executes: //Write cannot be performed, because the number of channels in the data does not match the number of channels in the task. //When writing, supply data for all channels in the task. Alternatively, modify the task to contain the same number of channels as the data written. //Number of Channels in Task: 3 //Number of Channels in Data: 1 //Task Name: _unnamedTask<0> //Status Code: -200524
I was also wondering if it is possible to write to a digital line individually using a logical line name (instead of having to write to all lines at the same time using an array)? If so, can you please provide a code example?
Thanks for your assistance.
Chris
03-24-2012 09:50 AM
Try using this
digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line0:2", string.Empty, ChannelLineGrouping.OneChannelForAllLines);
Curt
