Two USB6008 on different hubs - how to tell one from the other
My PC supports two instruments where each instrument consists of a hub, a USB6008 DAQ, and another mfg's DAQ. The two hubs plug into two respective USB ports on the PC.
I have code that walks the USB tree and finds each hub, and then in turn finds each device. This allows me to "pair" the two USB devices on a per hub basis. Although I have the info from walking the USB tree, I do not know the device name (e.g. Dev1) from just the USB info, so I am unable to explicitly open that device. Is there some way I can open a device based on it's USB hub/port location? It seem that all the channel open calls require the device name.
Thanks for any ideas.
Mitch
(3,753 Views)
Accepted by Mitch7
Read the serial number of the DAQ.  You should be then be able to find the name.  Maybe change the names from /dev1 to something more descriptive  when you set them up in MAX.
(3,723 Views)
Thanks Tom, I think that will work.
I was hoping for a more direct approach such as either opening a channel based on the serial number (which I can get from USB), or reading the device name from the USB info.
Mitch
(3,718 Views)
