USB 6008:How do you measure 500 results of ai0 and ai1@500 samples per sec.
well there were mistakes the first time!
Message 11 of 15
(1,966 Views)
I got It right!
there are 2 rows and 20 columns
thanks
Message 12 of 15
(1,937 Views)
Hi...
I am new to VB2010. i am now require to get sample code by using NI-6009 to measure voltage(Vrms) and Current (Irms).How about if i want to create multiple input multiple type analog channels in NI-6009 DAQ Card. I mean I would like to have  1 voltage and 1 current channels and i would like to display both of those in 2 separate graphs.For channei Dev2/ai0 to measure voltage and Dev2/ai1 for current using VB10.NI-6009 DAQ have 8 analog input channel.So, how if i want to use all the channel that can display waveform in separate graph in 1 device(NI-6009 DAQ).Below is the example of ContAcqVoltageSamples_IntClk that measure only one channel..The problem is can I modified this program so that i can use 8 channel that display 8 waveform in separate graph.But how?Because before this i tried but fail.anyone can help me.
Message 13 of 15
(1,234 Views)
Imports NationalInstruments.DAQmx
Public Class MainForm
    Inherits System.Windows.Forms.Form
    Private myTask As Task  'Main Task which is Assigned when the Start Button is Clicked
    Private runningTask As Task
#If NETFX2_0 Then
    Private data As AnalogWaveform(Of Double)()
#Else
    Private data As AnalogWaveform()
#End If
    Private analogInReader As AnalogMultiChannelReader
    Private analogCallback As AsyncCallback
    Private dataColumn As DataColumn()
    Friend WithEvents AxCWGraph1 As AxCWUIControlsLib.AxCWGraph
    Friend WithEvents AxCWGraph2 As AxCWUIControlsLib.AxCWGraph
    Friend WithEvents AxCWGraph3 As AxCWUIControlsLib.AxCWGraph
    Private dataTable As DataTable = New DataTable
  Private Sub startButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles startButton.Click
        If runningTask Is Nothing Then
            Try
                stopButton.Enabled = True
                startButton.Enabled = False
                ' Create a new task
                myTask = New Task()
                ' Create a virtual channel
                myTask.AIChannels.CreateVoltageChannel("Dev2/ai0:1", "", _
                    CType(-1, AITerminalConfiguration), -10, _
                  10, AIVoltageUnits.Volts)
                myTask.Timing.ConfigureSampleClock("", Convert.ToDouble(rateNumeric.Value), _
                    SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, 1000)
                ' Verify the Task
                myTask.Control(TaskAction.Verify)
                runningTask = myTask
                analogInReader = New AnalogMultiChannelReader(myTask.Stream)
                analogCallback = New AsyncCallback(AddressOf AnalogInCallback)
                ' Prepare the table for Data
                InitializeDataTable(myTask.AIChannels, dataTable)
                acquisitionDataGrid.DataSource = dataTable
#If NETFX2_0 Then
                ' For .NET Framework 2.0 or later, use SynchronizeCallbacks to specify that the object
                ' marshals callbacks across threads appropriately.
                analogInReader.SynchronizeCallbacks = True
                analogInReader.BeginReadWaveform(Convert.ToInt32(samplesPerChannelNumeric.Value), analogCallback, myTask)
#Else
                ' For .NET Framework 1.1, set SynchronizingObject to the Windows Form to specify
                ' that the object marshals callbacks across threads appropriately.
                analogInReader.SynchronizingObject = Me
                analogInReader.BeginReadWaveformDouble(Convert.ToInt32(samplesPerChannelNumeric.Value), analogCallback, myTask)
#End If
            Catch exception As DaqException
                MessageBox.Show(exception.Message)
                runningTask = Nothing
                stopButton.Enabled = False
                startButton.Enabled = True
                myTask.Dispose()
            End Try
        End If
    End Sub
Message 14 of 15
(1,230 Views)
Private Sub stopButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles stopButton.Click
        If Not (runningTask Is Nothing) Then
            myTask.Dispose()
        End If
    End Sub
    Private Sub AnalogInCallback(ByVal ar As IAsyncResult)
        Try
            If runningTask Is ar.AsyncState Then
#If NETFX2_0 Then
                data = analogInReader.EndReadWaveform(ar)
                'Plot your data here
                dataToDataTable(data, dataTable)
                analogInReader.BeginMemoryOptimizedReadWaveform(Convert.ToInt32(samplesPerChannelNumeric.Value), analogCallback, myTask, data)
#Else
                data = analogInReader.EndReadWaveformDouble(ar)
#End If
            End If
        Catch ex As DaqException
            MessageBox.Show(ex.Message)
            myTask.Dispose()
        End Try
    End Sub
#If NETFX2_0 Then
    Private Sub dataToDataTable(ByVal sourceArray As AnalogWaveform(Of Double)(), ByRef dataTable As DataTable)
        ' Iterate over channels
        Dim currentLineIndex As Integer = 0
        For Each waveform As AnalogWaveform(Of Double) In sourceArray
            Dim dataCount As Integer = 0
            If waveform.Samples.Count < 10 Then
                dataCount = waveform.Samples.Count
            Else
                dataCount = 10
            End If
            For sample As Integer = 0 To (dataCount - 1)
                dataTable.Rows(sample)(currentLineIndex) = waveform.Samples(sample).Value
            currentLineIndex += 1
    End Sub
#Else
    Private Sub dataToDataTable(ByVal sourceArray As AnalogWaveform(), ByRef dataTable As dataTable)
        For Each waveform As AnalogWaveform In sourceArray
            Else
                dataCount = 10
            End If
    End Sub
#End If
    Public Sub InitializeDataTable(ByVal channelCollection As AIChannelCollection, ByRef data As dataTable)
        Dim numOfChannels As Int16 = channelCollection.Count
        data.Rows.Clear()
        data.Columns.Clear()
        dataColumn = New DataColumn(numOfChannels) {}
        Dim numOfRows As Int16 = 10
        Dim currentChannelIndex As Int16 = 0
        Dim currentDataIndex As Int16 = 0
        For currentChannelIndex = 0 To (numOfChannels - 1)
            dataColumn(currentChannelIndex) = New DataColumn
            dataColumn(currentChannelIndex).DataType = System.Type.GetType("System.Double")
            dataColumn(currentChannelIndex).ColumnName = channelCollection(currentChannelIndex).PhysicalName
        data.Columns.AddRange(dataColumn)
        For currentDataIndex = 0 To (numOfRows - 1)
            Dim rowArr As Object() = New Object(numOfChannels - 1) {}
            data.Rows.Add(rowArr)
    End Sub
End Class
Message 15 of 15
(1,229 Views)
