06-28-2011 03:22 PM
After upgrading to VS 2010 SP1, I receive the following warning "Unable to find module dependency with signature Microsoft_VC100_ATL_x86.DF495DFD_79F6_34DF_BB1E_E58DB5BDCF2C" when I attempt to rebuild my installation program for distributing the application.
I have examined similar posts and have removed and reinstalled SP1, with not effect.
David
Solved! Go to Solution.
06-28-2011 04:35 PM
I found a solution listed at the following link --http://forums.ni.com/t5/Measurement-Studio-for-NET/Problems-building-Install
Shield-installer-after-upgrading-to-MS/td-p/1551002
07-19-2011 09:24 AM
I have found the same problem which is referenced in this post, but I have been unable to retrieve the solution from the referenced link. Do you have a new link?
Thanks .... John T.
07-19-2011 09:37 AM - edited 07-19-2011 09:39 AM
Cut and paste the entire link shown below:
http://forums.ni.com/t5/Measurement-Studio-for-NET/Problems-building-Install-Shield-
07-28-2011 01:18 PM
Thanks for the help. This saved me a lot of headaches.
08-17-2011 10:13 AM
See this post I wrote that might help clarify the situation.
