Updated version of Measurement Studio and now my controls say they aren't licensed.
The version of NI-DAQ that came with my copy of Measurement Studio 8 is messed up.  The first time I tried to install it it would blue screen the computer.  It is incredibly slow.  I just tried to reinstall MS and update the DAQ drivers and it got stuck for 5 minutes.  I need to go back out there and see if it has started now.  I don't know if this is the problem or not.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 11 of 17
(3,014 Views)
There is a knowledgebase article that describes the behavior you are experiencing, but the reason for the behavior in this article is an incorrect installation of Measurement Studio 8.0.  I do not believe this is your case, but maybe following these steps will solve your issue as well.
In particular, this article describes that if you try to modify your installation and add, or remove, some of the Measurement Studio components the license files might be created correctly.  The following is the knowledgebase article:
Measurement Studio 8.0 not Installing License for .NET Class Libraries
[http://digital.ni.com/public.nsf/websearch/AFE10646333929768625709A00798AD4?OpenDocument]
Please try following these steps and let us know if it fixes the issue.
Santiago D
Message 12 of 17
(2,990 Views)
I completely reinstalled MS and NI-DAQmx on Friday and I still have the same problem even though I have two license files.  I will try to modify the installation here shortly, but this is getting frustrating.  I'm trying to get them to let me use VB over LabVIEW and I'm having problems now that I didn't anticipate.  I'm running out of time.  I think I'm going to have to install my copy of 7.0 if this doesn't work.
Message Edited by SCXI and MS 2k3-VB.NET on 12-12-2005 08:42 AM
Message 13 of 17
(2,971 Views)
Hi
Looks like you are missing the WindowsForms license file. I would like to speed things up a bit, so could you post an email address I could use to contact you?
Bilal Durrani
NI
Message 14 of 17
(2,965 Views)
mchadwell @ swri.org
thanks.
Message 15 of 17
(2,962 Views)
Hello Joe Aggie
I wanted to make sure that you are also up and running. Have you managed to fix this issue or are you still stuck?
Let me know
Bilal Durrani
NI
Message 16 of 17
(3,019 Views)
Hi Elton,
Would you mind explaining where can I find that menu to refresh license.licx file?
Message 17 of 17
(1,178 Views)
