Use NI Vision (IMAQdx) with VS2010
When using IMAQdx in Visual Studio 2010 (C#), I received an error message which requires me to refer to an older verison of NI Common (8.7.35.131), which I don't have (I have 9.1.40.159). Is there anyway to walkaround, or where can I find the older version?
My sole purpose is to operate cameras via GiGE vision.
Thanks!
Best,
Yi
(4,682 Views)
Hi Yi,
I was able to find someone with a similar problem in this forum post.  Let me know if this looks like a similar error to yours, and if any of the steps listed help at all.  Additionally, I've seen similar issues in the past solved by updating to a more recent version of the drivers.  Let me know if this helps, or if you have any updates on the issue.
(4,664 Views)
Hi Kyle,
Thanks for your reply! My problem is a little different... I actually have problem compiling my code:
         Error 1 The type 'NationalInstruments.ISupportSynchronizationContext' is defined in an assembly that is not referenced. You must add a reference to assembly
         'NationalInstruments.Common, Version=8.7.35.131, Culture=neutral, PublicKeyToken=18cbae0f9955702a'.
I checked GAC, the config file (NationalInstruments.Common.config) looks like this:
<configuration>
  <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
      <dependentAssembly>
        <assemblyIdentity name="NationalInstruments.Common" publicKeyToken="dc6ad606294fc298"
                          culture="neutral" />
        <bindingRedirect oldVersion="7.0.0.275-7.1.40.999"
                         newVersion="9.1.40.159" />
        <bindingRedirect oldVersion="8.0.40.100-8.0.40.999"
        <bindingRedirect oldVersion="8.1.40.100-8.1.40.999"
        <bindingRedirect oldVersion="8.5.40.100-8.5.40.999"
        <bindingRedirect oldVersion="8.6.40.100-8.6.40.999"
        <bindingRedirect oldVersion="8.7.40.100-8.7.40.999"
        <bindingRedirect oldVersion="8.9.40.100-8.9.40.999"
        <bindingRedirect oldVersion="9.0.40.100-9.0.40.999"
        <bindingRedirect oldVersion="9.1.40.100-9.1.40.158"
      </dependentAssembly>
    </assemblyBinding>
  </runtime>
</configuration>
It didn't try to redirect 8.7.35.131. But even if I manually edit the file to do it, compiler still reports error... (I'm using MS VS .Net 2010)
I already installed the newest driver (August, 2011). I read from the release note that its development enviroment includes VS .Net 2005/2008, but doesn't mention VS2010...
P.S. In my code, if I reference NI Common 9.0.40.610 (for vs 2008), it compiles without a problem...haven't had a chance to test the code with camera yet. Will update later.
Best,
Yi
(4,652 Views)
Sorry about a typo in my previous post. NI Common for 2008 should be 9.1.35.139
(4,649 Views)
Another possibility here is that it could be a .NET version issue.  Can you try changing your project settings to target .NET 3.5 and see if that makes any difference?
(4,643 Views)
Update:
NI Common 9.0.40.610 (for vs 2008) works just fine with VS2010 and .net 4... Good enough for me.
(4,610 Views)
