Using DataSocket Server in Windows Service app .Net
I am using measurement studio and Daqmx to pick data from NI ELVIS II. The software am developing involves using a DataSocket server and works fine if testing in a Console application or windows forms. However, when I transfer the code to a windows service, other things run fine but am not able to start the datasocket server to stream the data that I pick from the NI ELVIS II board.  Am asking if there is something that I can do in order to be able to run the dataScoket Server in the Windows service app.
Thank you!
(2,984 Views)
When you say that you are not able to start the datasocket server to stream, are you seeing any errors? How have you configured the datasocket server?
(2,964 Views)
Accepted by ashirafumiiro
I managed to figure it out.
The data Socket server was running as system user so I could not see the config GUI but with the right reading address, everything worked fine
(2,960 Views)
