05-23-2008 10:02 AM
You mean this ?
Paul
0:000> g
ModLoad: 76180000 76246000 C:\Windows\system32\ADVAPI32.dll
ModLoad: 764c0000 76583000 C:\Windows\system32\RPCRT4.dll
ModLoad: 76460000 764b8000 C:\Windows\system32\SHLWAPI.dll
ModLoad: 777f0000 7783b000 C:\Windows\system32\GDI32.dll
ModLoad: 76610000 766ad000 C:\Windows\system32\USER32.dll
ModLoad: 77470000 7751a000 C:\Windows\system32\msvcrt.dll
ModLoad: 75ef0000 75f0e000 C:\Windows\system32\IMM32.DLL
ModLoad: 77520000 775e8000 C:\Windows\system32\MSCTF.dll
ModLoad: 75f10000 75f19000 C:\Windows\system32\LPK.DLL
ModLoad: 775f0000 7766d000 C:\Windows\system32\USP10.dll
ModLoad: 74c60000 74dfe000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_5cdbaa5a083979cc\comctl32.dll
ModLoad: 79e70000 7a3ff000 C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
ModLoad: 71ef0000 71f8b000 C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.1434_none_d08b6002442c891f\MSVCR80.dll
ModLoad: 76890000 7739f000 C:\Windows\system32\shell32.dll
ModLoad: 76740000 76884000 C:\Windows\system32\ole32.dll
ModLoad: 790c0000 79bf6000 C:\Windows\assembly\NativeImages_v2.0.50727_32\mscorlib\5b3e3b0551bcaa722c27dbb089c431e4\mscorlib.ni.dll
ModLoad: 74f60000 74f9f000 C:\Windows\system32\uxtheme.dll
ModLoad: 79060000 790b6000 C:\Windows\Microsoft.NET\Framework\v2.0.50727\mscorjit.dll
ModLoad: 7a440000 7ac2a000 C:\Windows\assembly\NativeImages_v2.0.50727_32\System\267d4c344058092e6950c11594244f90\System.ni.dll
ModLoad: 7ade0000 7af7c000 C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Drawing\a35f567c4c67d6b1ca9a0023852847a2\System.Drawing.ni.dll
ModLoad: 7afd0000 7bc6c000 C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Windows.Forms\45ee94a63c463b93e3ff694c6ecd0820\System.Windows.Forms.ni.dll
ModLoad: 58e40000 5930a000 System.Windows.Forms.dll
ModLoad: 64890000 6498c000 C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Configuration\15366cc16c2550064601b5167821667d\System.Configuration.ni.dll
ModLoad: 637a0000 63d28000 C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Xml\02cf61328d59df9b3ec09544f449a781\System.Xml.ni.dll
ModLoad: 74140000 742eb000 C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6001.18000_none_9e752e5ac9c619f3\gdiplus.dll
ModLoad: 766b0000 76734000 C:\Windows\system32\CLBCatQ.DLL
ModLoad: 77840000 778cd000 C:\Windows\system32\OLEAUT32.dll
ModLoad: 632c0000 632fc000 image632c0000
ModLoad: 01c40000 01c7c000 image01c40000
ModLoad: 75240000 7527b000 C:\Windows\system32\rsaenh.dll
ModLoad: 632c0000 632fc000 C:\Windows\assembly\GAC_32\NationalInstruments.Analysis.Enterprise\8.1.20.472__4544464cdeaab541\NationalInstruments.Analysis.Enterprise.dll
ModLoad: 75640000 75648000 C:\Windows\system32\VERSION.dll
ModLoad: 6bac0000 6baf2000 image6bac0000
ModLoad: 01ca0000 01cd2000 image01ca0000
ModLoad: 6bac0000 6baf2000 C:\Windows\assembly\GAC_MSIL\NationalInstruments.Common\8.1.20.415__4544464cdeaab541\NationalInstruments.Common.dll
ModLoad: 65f20000 66b14000 C:\Windows\assembly\NativeImages_v2.0.50727_32\System.Web\369cdfcbaefd8f28200e295c26c2141f\System.Web.ni.dll
ModLoad: 75660000 756a5000 C:\Windows\system32\bcrypt.dll
ModLoad: 10000000 100d6000 C:\Program Files\National Instruments\Shared\Analysis\nianlys.dll
ModLoad: 04080000 040b6000 C:\Program Files\National Instruments\Shared\MKL\MKL70\libguide40.dll
ModLoad: 044f0000 04721000 C:\Program Files\National Instruments\Shared\MKL\MKL70\mkl_def.dll
ModLoad: 04730000 049e4000 C:\Program Files\National Instruments\Shared\MKL\MKL70\mkl_p3.dll
ModLoad: 049f0000 04d46000 C:\Program Files\National Instruments\Shared\MKL\MKL70\mkl_p4.dll
ModLoad: 04d50000 05089000 C:\Program Files\National Instruments\Shared\MKL\MKL70\mkl_p4p.dll
ModLoad: 05090000 052ab000 C:\Program Files\National Instruments\Shared\MKL\MKL70\mkl_lapack64.dll
(fcc.1788): Access violation - code c0000005 (first chance)
First chance exceptions are reported before any exception handling.
This exception may be expected and handled.
eax=001fdf90 ebx=00000019 ecx=044e44a0 edx=001fe5f0 esi=044e3d80 edi=001f8f7c
eip=001fb788 esp=001f8eb8 ebp=001fe5ec iopl=0 nv up ei pl nz na pe nc
cs=001b ss=0023 ds=0023 es=0023 fs=003b gs=0000 efl=00010206
001fb788 57 push edi
05-23-2008 11:29 AM
05-23-2008 12:50 PM
I have a few copies on the machine, mostly because I could never get the merge modules to work correctly from WIX, but non of these are on the search path. There are actually 2 in the National Instruments tree though and I don't know which it would prefer ?
Paul
Directory of C:\Program Files\National Instruments\CVI85\bin\rtsupp
23/10/2007 11:00 1,282,048 nianlys.dll
1 File(s) 1,282,048 bytes
Directory of C:\Program Files\National Instruments\Shared\Analysis
23/05/2008 15:43 856,064 nianlys.dll
1 File(s) 856,064 bytes
05-23-2008 12:58 PM
06-06-2008 03:18 PM
06-06-2008 03:34 PM
06-16-2008 04:41 PM
06-16-2008 04:56 PM
