WPF Graph - How to retrive horizontal & veritcal values when Zoom performed by GraphInteractionPalette
I am using WPF graph and its  data changes continuously every 50ms.
I set XAxesRangeAdjuster  to FitExactly and I want to use GraphInteractionPallete to Zoom/ZoomHorizontal/ZoomVertical/ZoomIn/ZoomOut interactions.
When I  select area and want to ZoomHorizontal it resets because new data changes the range again.
I want to set range manually in ViewModel  and  select graph data manually  when Zoom event occurred.
How could we get selected area start&end positions?
Is there a event or something else when ZoomToFit or another button clicked?
Best Regards,
(2,829 Views)
Accepted by yrnhkn
I am traveling this month, so I will not be able to test anything directly, but I believe  the Range Changed event on the axis will notify you of all range changes. Then you can use a preview click event ( https://forums.ni.com/t5/Measurement-Studio-for-NET/WPF-Legend-Item-Mouse-Event/m-p/2428032 ) to update the Adjuster after a legend button causes a range change.
~ Paul H
(2,802 Views)
Hi Paul,
Thank you for solution 🙂
Best Regards,
Hakan
(2,791 Views)
