WPF Graph thread issue
We are using binding on the Datasource and update the binded data in a thread. Similar to the issues described in M16525, but even though we are using the dispatcher to invoke the main thread it seems we sometimes get a race condition. I have created a simple example using a timer to illustrate the issue. I have set the timer frequency high to quickly provoke the error. Are we doing something wrong or is it not possible to update safe in a thread calling back to main thread? The error we get is “System.Reflection.TargetInvocationException: 'Exception has been thrown by the target of an invocation.'”
Example (Doesn’t fail each time, but fails on startup if you start it a couple of times):
public partial class MainWindow : Window
   private Random rand;
   private ObservableCollection<ChartCollection<DateTime, double>> trendData;
   private Timer timer;
   public MainWindow()
      InitializeComponent();
      rand = new Random();
      trendData = new ObservableCollection<ChartCollection<DateTime, double>>();
      trendData.Add(new ChartCollection<DateTime, double>(10000));
      DataContext = this;
      this.timer = new Timer(OnTimerElapsed);
      this.timer.Change(0, 10);
   private void OnTimerElapsed(object stat)
      this.Dispatcher.Invoke(
       new Action(() => { plot(); }));
   private void plot()
      trendData[0].Append(DateTime.Now, 10 * rand.NextDouble());
   public ObservableCollection<ChartCollection<DateTime, double>> TrendData
      get => this.trendData;
XAML:
<Grid>
   <ni:Graph DataSource="{Binding TrendData}" RenderMode="Raster">
   </ni:Graph>
</Grid>
(3,154 Views)
Accepted by OddvarC
First, to fix the exception, add niPrimitives:GraphConfiguration.UseBackgroundProcessing="False" to the XAML for your graph (xmlns:niPrimitives="http://schemas.ni.com/controls/2009/xaml/presentation/primitives").
To give a little more background, the disposed exception occurs because of an optimization made by the chart collection: when the graph requests access to the chart data, the chart returns a reference to the live data in the collection. This avoids a memory copy, but means that any change to the chart can invalidate the data held by the graph.
Also, thank you for including that small example program — this made it very easy to diagnose the issue! For future reference, you can look at the InnerException to see what actually caused the target invocation to fail.
~ Paul H
(3,128 Views)
Thanks a quick reply Paul, this seems to fix the issue!
(2,885 Views)
