WPF IntensityGraph, display cell value on mouse event
Is there a way to display value of a cell in a "tooltip-like" popup when you click/hover anywhere on IntensityGraph?
Thank you
(4,886 Views)
Accepted by kirko7
Using the technique from WPF graph display point value on hover, here is a version specific to intensity data:
    private static readonly GraphQueryArgs query = new GraphQueryArgs(
        PlotsToSearch.Any, SearchDimensions.HorizontalAndVertical,
        SearchDirections.ForwardAndReverse, isInclusive: true );
    public MainWindow( ) {
        InitializeComponent( );
        graph.PlotAreaMouseMove += this.OnPlotAreaMouseMove;
        graph.PlotAreaMouseLeave += delegate { graph.ToolTip = null; };
        ToolTipService.SetInitialShowDelay( graph, 0 );
        ToolTipService.SetShowDuration( graph, int.MaxValue );
    private void OnPlotAreaMouseMove( object sender, MouseEventArgs e ) {
        IPlot plot = graph.AllPlots[0];
        Point screenPosition = graph.GetPlotAreaPosition( e );
        Point relativePosition = graph.ScreenToRelative( screenPosition );
        PlotValue nearestValue = graph.FindNearestValue( plot, relativePosition, query );
        if( nearestValue != null )
            graph.ToolTip = string.Format(
                "Nearest intensity value is {2} at ({0},{1}).",
                nearestValue.Value.Cast<object>( ).ToArray( ) );
~ Paul H
(4,856 Views)
Much appreciated!
(4,843 Views)
