WPF graph: cannot disable annotation movement
When I set InteractionMode = AnnotationInteractionModes.None, I still can move annotation by dragging the circle (this is point annotation). How do I disable this movement altogether.
(6,332 Views)
Accepted by eugenem
This appears to be an issue with how the annotations implement the “drag target” interaction mode. I have created a task to fix this.
As a workaround, you can add and remove the annotation from the graph:
    annotation.InteractionMode = AnnotationInteractionModes.None;
    graph.Children.Remove( annotation );
    graph.Children.Add( annotation );
This will force the annotation to re-initialize the drag handling to match the current InteractionMode value.
~ Paul H
(6,322 Views)
Just wanted to let you know this issue (#391307) was fixed in the Measurement Studio 2015 release.
~ Paul H
(4,815 Views)
