WPF slider - How do I change the format of the values in the scale to Hex or other?
In the non-WPF version of the slider control I could change the displayed scale format to different styles of values. In this case, I would switch the displayed values to Hex.
slideIccMax.MajorDivisions.LabelFormat = newFormatString(FormatStringMode.Numeric, "X4");
in WPF, I cant find an equivalent to "MajorDivisions.LabelFormat". Has this capability been removed for the WPF version of the slider control?
(8,883 Views)
Accepted by FoxGrove
Display of labels is controlled by the LabelPresenter property on the MajorDivisions of the numeric scale:
    <ni:SliderInt32 Range="1, 16383, System.Int32">
        <ni:SliderInt32.Scale>
            <ni:NumericScale>
                <ni:NumericScale.MajorDivisions>
                    <ni:RangeLabeledDivisions LabelPresenter="X4" />
                </ni:NumericScale.MajorDivisions>
            </ni:NumericScale>
        </ni:SliderInt32.Scale>
    </ni:SliderInt32>
~ Paul H
(8,865 Views)
Paul - Thanks! That will work!
One more question is how would you change that through code (like C# or VB)? The NI help is very sparse on how you work with the LabelPresenter or MajorDivisions.
Chris
(8,857 Views)
You can use any type derived from ValuePresenter. By default, we use a GeneralValueFormatter, which takes .NET format strings like X4. So in code:
    majorDivisions.LabelPresenter = new GeneralValueFormatter( "X4" );
I have created a task to update the documentation.
~ Paul H
(8,854 Views)
I saw this thread when looking for an approach to one of my tasks.
I have an app using the WPF graph which has a menu option to change the axis units between Inch and Millimeter.
I tried to use the "in code" option as shown in the above response set the LabelPresenter when the user changes the menu setting. However, whenever I get to the statement to set the LabelPresenter, I keep getting this exception:
"Cannot set a property on object 'NationalInstruments.Controls.RangeLabeledDivisions' because it is in a read-only state."
And a QuickWatch of the full set of properties show the "IsFrozen" property set to "true".
I am trying to avoid having to go through a process to have to convert the complete dataset of actual plotted values, and just change the axis labels.
Any insight would be helpful.
(8,615 Views)
For scales, the default values of properties like MajorDivisions are set to frozen values that are shared across all scales (if the values were not frozen, then assigning a label presenter on the default value would change every scale in every control).
To avoid the error, all you need to do is assign a unique instance once to the axis you want to modify. You can set this once in code or in XAML (e.g. axis.MajorDivisions = new RangeLabeledDivisions() in the constructor, or declaring the axis with an empty <RangeLabeledDivisions/> XAML child element).
~ Paul H
(8,612 Views)
Thanks Paul.
I used the empty <RangeLabeledDivisions/> XAML child element, and am changing the LabelPresenter in the dependency property for the selected axis dimension.  This is working perfectly.
(8,592 Views)
