drag xy cursor and InteractionModeDefault to zoomxy
Thks for your answer.
can you give an example because i do'nt manage coding zoom in and out through ZoomXY method...
thks by advance
Message 11 of 18
(2,408 Views)
Hello -
There are a couple different overloads on the ZoomXY method.  The snippet below shows the overload that takes a plot, and four doubles, and may be a good place for you to start from.  This is just a very simple handling of the mouse wheel scrolling.
private void waveformGraph1_PlotAreaMouseWheel(object sender, MouseEventArgs e)
    RectangleF rect = new RectangleF();
    if (e.Delta > 0)
        rect.X = (float)waveformPlot1.XAxis.Range.Minimum - 1;
        rect.Y = (float)waveformPlot1.YAxis.Range.Minimum - 1;
        rect.Height = (float)(waveformPlot1.YAxis.Range.Maximum -
            waveformPlot1.YAxis.Range.Minimum + 2);
        rect.Width = (float)(waveformPlot1.XAxis.Range.Maximum -
            waveformPlot1.XAxis.Range.Minimum + 2);
        waveformGraph1.ZoomXY(waveformPlot1, rect.X, rect.Y, rect.Width, rect.Height);
    else
        rect.X = (float)waveformPlot1.XAxis.Range.Minimum + 1;
        rect.Y = (float)waveformPlot1.YAxis.Range.Minimum + 1;
            waveformPlot1.YAxis.Range.Minimum - 2);
            waveformPlot1.XAxis.Range.Minimum - 2);
Let me know if you have any questions about this snippet
NickB
Message 12 of 18
(2,405 Views)
Hello sstrenn,
I have a similar issue with my customer.
I derived my own control from the ScatterGraph and used ScatterPlot.ZoomXY() to implement Zoom/Unzoom features as per their wishes.
Message 13 of 18
(2,391 Views)
I have same problem.
I try solution described above without success. It resize but not correctly. I use scatterGraph.
I wonder if there is 2 public methods :ZoomIn and ZoomOut to ensure standard behavior. They should have something internally. Why just don't let those 2 functions available to us ?
It will ensure standard behavior all the time and enable customers to zoom the way they want.Smiley Wink
Eric
Message 14 of 18
(1,765 Views)
Hey Eric,
What version of Measurement Studio are you using? The graph control may be different in your version.
Message 15 of 18
(1,743 Views)
Hi D Biel,
Thanks for your feedback.
In fact I solved my problem with the following code. It resize without modifiers keys but also enable me to resize only in X or Y depending on "Alt" or "Ctrl" key. It also have the advantage to resize the same ratio as NI default.
Also note that my code should work in any situation (I think).
Also... NI Should give us access to there "ZoomIn" and "ZommOut" function. It take only 5 minutes of development time and save us and also NI support a lot of time and troubles. Smiley Wink
Eric
		private void scatterGraph1_PlotAreaMouseWheel(object sender, MouseEventArgs e)
if (!(Keyboard.IsKeyDown(Key.LeftShift) || Keyboard.IsKeyDown(Key.RightShift))) // No shift, do not overide default behavior
double zoomFactor;
if (e.Delta > 0)
zoomFactor = .8; // .008 = 1/1.25, same as NI
else
zoomFactor = 1.25;
rect.X = (float)scatterGraph1.Plots[0].XAxis.Range.Minimum;
rect.Width = (float)(scatterGraph1.Plots[0].XAxis.Range.Maximum - scatterGraph1.XAxes[0].Range.Minimum);
rect.Y = (float)scatterGraph1.Plots[0].YAxis.Range.Minimum;
rect.Height = (float)(scatterGraph1.Plots[0].YAxis.Range.Maximum - scatterGraph1.YAxes[0].Range.Minimum);
double newWidth = rect.Width * zoomFactor;
double newHeight = rect.Height * zoomFactor;
if (Keyboard.Modifiers == 0)
scatterGraph1.ZoomXY(scatterGraph1.Plots[0], rect.X + ((rect.Width - newWidth) / 2),
 rect.Y + ((rect.Height - newHeight) / 2), newWidth, newHeight);
else
if (Keyboard.IsKeyDown(Key.LeftAlt) || Keyboard.IsKeyDown(Key.RightAlt))
Debug.Print("Alt");
scatterGraph1.ZoomXY(scatterGraph1.Plots[0], rect.X,
 rect.Y + ((rect.Height - newHeight) / 2), rect.Width, newHeight);
else if (Keyboard.IsKeyDown(Key.LeftCtrl) || Keyboard.IsKeyDown(Key.RightCtrl))
Debug.Print("Ctl");
 rect.Y, newWidth, rect.Height);
Message 16 of 18
(1,734 Views)
Thanks for the great code Eric!
Message 17 of 18
(1,716 Views)
I made a slight modifcation to this sample code so that the zoom would occur only in the X direction and around the position of mouse.
The largest change is the scaling factor (originally it was 0.5 or "/2".  By using the PointToVirtual function you get a value from 0 to 1 for X which is a normalized mouse position on the X axis. Using this as the scaling factor for the X start position of the zoom causes the zoom to happen around the mouse position.  It's much more intuitive and doesn't require any panning after the zoom.  Thanks for the original idea it works great!.
PointF pos = waveformGraph1.PointToVirtual(e.Location);
        bool mouseWheelEvent = false;
            try
                mouseWheelEvent = true;
                if (!(Control.ModifierKeys == Keys.LShiftKey) && !(Control.ModifierKeys == Keys.RShiftKey))
                //  if (!(Keyboard.IsKeyDown(Key.LeftShift) || Keyboard.IsKeyDown(Key.RightShift))) // No shift, do not overide default behavior
                    double zoomFactor;
                    if (e.Delta > 0)
                    else
                        zoomFactor = 1.25;
                    rect.X = (float)waveformGraph1.Plots[0].XAxis.Range.Minimum;
                    rect.Width = (float)(waveformGraph1.Plots[0].XAxis.Range.Maximum - waveformGraph1.XAxes[0].Range.Minimum);
                    rect.Y = (float)waveformGraph1.Plots[0].YAxis.Range.Minimum;
                    rect.Height = (float)(waveformGraph1.Plots[0].YAxis.Range.Maximum - waveformGraph1.YAxes[0].Range.Minimum);
                    if (Control.ModifierKeys == 0)
                        waveformGraph1.ZoomXY(waveformGraph1.Plots[0], rect.X + ((rect.Width - newWidth) * pos.X),
                    else
                        if (Control.ModifierKeys == Keys.Alt)
                            Debug.Print("Alt");
                            waveformGraph1.ZoomXY(waveformGraph1.Plots[0], rect.X,
                        else if (Control.ModifierKeys == Keys.LControlKey || Control.ModifierKeys == Keys.LControlKey)
                            Debug.Print("Ctl");
                            waveformGraph1.ZoomXY(waveformGraph1.Plots[0], rect.X + ((rect.Width - newWidth) / 2),
            catch (Exception exp)
Message 18 of 18
(1,413 Views)
