export sample or reference clock in C#
I am looking for a way to export the reference clock for a particular device or sample clock for a particular task to one of the PFI lines on my m-series device. I am programming in C#. I saw methods such as
DAQmxConnectTerms
and
DAQmxExportSignal
for the C API, but no corresponding methods for C#. According to the 6259 m-series manual, I should be able to at least export a sample clock to a PFI line, if not the actual reference clock. Thanks.
-Jon
(4,918 Views)
Hello Jon,
There are, in fact, equivalent calls in C#.  You can find more information about them in Visual Studio's Object Browser under National Instruments.DAQmx >> ExportSignals.  A screenshot of this is found below.  Hope this helps!
Joe s.
(4,912 Views)
Thanks Joe, that is very promising.
My problem now is that I don't know how to use this method. Reading the object explorer and  the NI-DAQmx .NET Framework 3.5 Help explore provided little insight. Specifically, I declare an ExportSignals object like so:
internal ExportSignals exSig;
later I try to make an instance of this object
exSig = new Exportsignals();
However, I get an error saying that ExportSignals has no constructor. It does not seem like ExportSignal is a static method of ExportSignals because I need to at least declare exSig before I get references to the ExportSignal method in intellisense.
Do you have a code example in which this class is used correctly? Thanks!
-Jon
(4,903 Views)
Accepted by neuronerd
Jon,
After a bit more research, I've found a method that might be even better for your application.  In the DaqSystem class, there is a method called "ConnectTerminals" that lets you specify signals to connect together.  The syntax will be similar to this:
DaqSystem.Local.ConnectTerminals("/Dev1/Ctr0InternalOutput", "/Dev1/PFI1");
You can find documentation on this in the Object Browser under NationalInstruments.Daqmx.DaqSystem.  Let me know how this one might work for you.
Joe S.
(4,899 Views)
Yes Joe, that did what I needed. Thank you very much.
- Jon
(4,886 Views)
