The problem stems from trying to use the value 0 for the minimum of a logarithmic scale.
To fix this, you need to set the lower end of your range to a value close to, but greater than 0.
See the following forum post for more detailed information, and let us know if you are still having this problem.
http://forums.ni.com/ni/board/message?board.id=232&message.id=1103&requireLogin=False
Thanks cju, have a good one!
Dan Weiland
Applications Engineer
Dan Weiland
