log scale won't scale to show small values
I have very small values to scale... all peaks of less then .0005. No matter what I try, I cannot get a logorithmic scale to scale that small. Besides multiplying everything by 100000, is there anyway to get the axis to scale these properly?
The following code produces a graph with a vertical scale of 0-10:
WaveformGraph
yAxis1.ScaleType = ScaleType.Logarithmic;
yAxis1.LogBase = 10;
yAxis1.Range = Range.Parse("0,.001");
(4,877 Views)
Hi cju,
It appears as though when you apply the logarithmic scale, if you enter in any value less than 1 for the maximum range, the waveform graph defaults to 10. I am investigating this behavior further.
Does your data set contain values outside of the .001 maximum you are trying to specify? If you make sure the axis.mode property is not set to "fixed", and don't specify the range, does the scaling work properly?
I'll let you know what I find on my end. Thanks for your patience cju.
Dan Weiland
Dan Weiland
(4,863 Views)
The scaling always defaults to 1-10 even when not set to fixed. There are no values outside the range of the axis I am trying to plot. So for instance if my scale is (0,.001) my values are from 0 to .0005. Right now I have to set the graph to a normal scale but the customer must have a log scale.
I thought it had something to do with smaller values and log graphs in general so I tried to plot them in Excel and that scaled fine.
(4,859 Views)
The problem stems from trying to use the value 0 for the minimum of a logarithmic scale.
To fix this, you need to set the lower end of your range to a value close to, but greater than 0.
See the following forum post for more detailed information, and let us know if you are still having this problem.
http://forums.ni.com/ni/board/message?board.id=232&message.id=1103&requireLogin=False
Thanks cju, have a good one!
Dan Weiland
Dan Weiland
(4,843 Views)
