parameters in LabView VI at runtime
Hi
  I am new to LabView. I am working on an application that can load and run any VI.
 I am trying to run a VI from C# application. Given the VI name, how do i find out what all parameters the VI has?
lv =
new LabVIEW.ApplicationClass();
//Set the path to the VI
string vipath= "c:\\temp\\arith.vi";
//Get reference to that VI
vi= lv.GetVIReference(vipath,"",
true,0);
Before calling , vi.Call(ref param1,ref param2);
I want to get the param info from the VI itself,  instead of hard coding in the application code.
thanks
(3,833 Views)
Hi Sruthi,
I am not sure if I am understanding the question correctly.   As far as I understand, you are trying to call a VI in .NET and you are able to ge a  VI reference but you want to know what are the inputs to the VI so you could pass values for those inputs? Am I correct ? Please clarify.
Ankita
(3,801 Views)
Yes.I found my answer.I am calling ExportVIStrings which generates a text file with all the controls used in the VI. I use this info to find out the list of input and output parameters.
But,  i have another problem now. How do i pass values for cluster data type, from a C# code?
thanks
(3,793 Views)
I got the answer for the  cluster data type question also. Thanks to http://detritus.blogs.com/lycangeek/2005/09/calling_lv_from.html.
(3,786 Views)
