property editor - Apply invariant culture
I have a property editor with the following configuration:
object: scatterplot
property name: PointSize
The problem is that its representation depends on regional settings, for example:
Spanish is: "5; 5"
United States is : "5, 5"
So how to make it culture invariant in order to represent always in the same manner?
(5,861 Views)
Accepted by tonitpp
Hi there,
Write this peice of code at the beginning of your code.
Thread.CurrentThread.CurrentCulture = new CultureInfo("", false);
This will make the locale to be set to invariant. But this causes culture to be invariant across the thread.
Hope this helps.
Vijet Patankar
(5,855 Views)
object: scatterplot
Spanish is: "5; 5"
EDIT
- How to get which character separator is used by the property editor?
- Can I force property editor source to use a custom separator?
The need to get the character separator is because I control what user is typing, so I only permits to user to use digits and the character separator so I need to check this character separator to allow user to type it.
(5,854 Views)
Ok, but this will apply culture invariant to all application. Is there any way to know which character separator is using propertyeditorsource?
(5,853 Views)
Ok, as you says in the another thread
by using CultureInfo.CurrentCulture.TextInfo.ListSeparator.
(5,848 Views)
