synchronizing M-Series Analog Input
Has anyone successfully synchronized two or more boards?
for continuous AI acquisition ?
in C# or VB ?
Thanks.
Philip Newman
General Dynamics
Electric Boat
Message 1 of 10
(5,497 Views)
Philip,
There is a multi-device, AI synchronization example that should install in the following location:
C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\DAQmx\Synchronization\Multi-Device\AIFiniteAcquisition
Please let us know if you have any problems with this.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
Message 2 of 10
(5,475 Views)
i need to  do continuous sampling
and the NI example (for continuous synched sampling ) does not work
i thought someone out there may have found a way to do it
Philip Newman
General Dynamics
Electric Boat
Message 3 of 10
(5,472 Views)
Philip,
Try the Measurement Studio example located here:
C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\DAQmxWithUI\SynchronizeTwoAIContinuous
Ryan Verret
Signal Generators
Message 4 of 10
(5,471 Views)
yeah
that's the one that does not work
i have a reference number with NI app eng
but maybe someone "out there" has managed to get it working
or maybe there is some other method?
Philip Newman
General Dynamics
Electric Boat
Message 5 of 10
(5,468 Views)
I have got the same problem. I want to synchronize two M series cards (PCI 6250). I've got the AIFiniteAcquisition example working, but I want to read in continuous samples.
I have changed the setting Timing.ConfigureSampleClock in the SyncTask.cs from SampleQuantityMode.FiniteSamples to SampleQuantityMode.ContinuousSamples. But that doesn't work.
Has anyone solved the problem? What do I have to change?
I have read about an example program SynchronizeTwoAIContinuous but I can't find this on my harddisc. Couls anyone please send me the code or better the whole project file?
BJ_O
Message 6 of 10
(5,300 Views)
[deleted]
Message Edited by serpos on 06-14-2006 06:54 AM
Philip Newman
General Dynamics
Electric Boat
Message 7 of 10
(5,291 Views)
twoAIsyncCont attached
Philip Newman
General Dynamics
Electric Boat
Message 8 of 10
(5,287 Views)
Thank you serpos,
but that isn't working for me, because I am not using Measurement Studio. I think I need it to run the c#-program. Any other ideas?
BJ_O
Message 9 of 10
(5,252 Views)
cs.zip is the C# example
but the example ships with measurement studio and uses measurement studio classes.
you need to code directly to NIDAQ
and this option has been discussed in this forum
cheers
Philip Newman
General Dynamics
Electric Boat
Message 10 of 10
(5,237 Views)
