what to install for .Net C# development
I'm using a USB6009 device. From what I've read, there is good .Net support for using the various DAQmx method.
Can someone tell me which installer to download so I can have the .Net support from Visual Studio? I don't need to complete suite of tools just the .Net and Visual Studio support. (other people in my company use the other tools targeted for experimenting with the various hardware devices. I know I'm using USB6009 IO device and I need to talk to it via C#.
I am using VS2010 and VS2008
NI has a vast number of products and I've spent a good 30 minutes trying to figure out what I need. BUt I'm still not sure.
(3,866 Views)
Hello Mitch7,
After looking at your question, I believe the best option for you is to download DAQmx 9.2.2 for USB-6009. Unfortunately, DAQmx 9.2.2, which is the latest driver, doesn't currently support .NET programming in Visual Studio 2010 but it does support ANSI C programming in it. If you have Visual Studio 2008, you should be able to program with your USB-6009 without any issues with DAQmx 9.2.2.
Jim St
RF Product Support Engineer
(3,853 Views)
Jim,
Thanks for the link. I ran that installer, found the assemblies it instaled, and then added references to those assemblies from my project.My project now runs and I can use the DAQmx calls.
Keep in mind that over the past few weeks, I have run other NI installers to get the functions that are used by the existing unmanaged C++ working. That NI installer took about 15 minutes and installed a whole bunch of services and also screws up the ipconfig on my PC after a reboot (It adds a default route of 0.0.0.0. when the PC restarts. This is a known problem BTW).
A couple of more questions:
1) On a clean system, is that the only installer I would need to run? Or do I even need to run the installer? Can I just redistribute the assemblies?
2) The installer put everything under "d:\temp\NiDaq_installed". This is a strange locations. Most of theNI  docs I've read mention that they should have been put under program files\National Instruments ...  I ran the installer as an administrator. Any idea why it is under D:\temp?
3) I am hoping that for deploying our product to a customer, we only need to copy the assemblies and dlls, and not force the customer to run an NI installer. Is that possible?
My dev machine is Win7 64 and I am using VS2010 for most work. I do have VS2008 also installed.
Mitch
(3,844 Views)
Hello Mitch7,
Not a problem. As for your questions, I have answered them below:
If you want to develop on a new machine, you will need to have the full DAQmx driver installed. Moving the assemblies will not be enough to give you access to the cards.
Not I am not sure why this is under this temp folder. Usually the temp folder can have the extracted installed documents for DAQmx. Has a National Instruments folder been created?
For deploying this on a different machine as an exe, you don't need to have the full driver installed only the run-time. There are two different run-times that include MAX or don't include it. I would HIGHLY advise installing MAX because if the customer has any problems with the cards, this will be the best way to debug the problem.  I have also found a Knowledgebase explaining how to install this runtime after installing exe.
Jim St
(3,827 Views)
