wpf engineering value formatting
In Measurement Studio WF there is engineering formatter:
NationalInstruments.UI.FormatString fs = new NationalInstruments.UI.FormatString(NationalInstruments.UI.FormatStringMode.Engineering, "S2");
Is there similar formatter in WPF? I've found only standard formatters like
var fs = new GeneralValueFormatter("0.###");
(7,373 Views)
Hi Eugenem
The closest thing I can find is the EngineeringFormatInfo class, although it's not a WPF element.
I don't believe there is currently a WPF string formatting class or namespace which is part of the Measurement Studio package.
Kind Regards
Chris | Applications Engineer NIUK
(7,372 Views)
thanks!
this one is good for manual formatting
how do I apply it to graph axis?
now I use
ax.MajorDivisions.LabelPresenter = new GeneralValueFormatter( config.format );
(7,365 Views)
Hi Again
I've taken another look and in WPF the graph formatting is done using XAML, unfortunately the only formatting options for the axis numeric that I can see are DateTime, Double, Int32 or PrecisionDateTime. i.e. the attached picture.
I think the answer to your original question is no for the moment.
Kind Regards
(7,358 Views)
Accepted by eugenem
As Chris mentioned, the WPF controls do not currently support engineering format values. However, implementing a custom formatter using the EngineeringFormatInfo class is fairly trivial, and does not involve creating a new axis type.
See the attached file for an example implementation. You can use it in your code like so:
    ax.MajorDivisions.LabelPresenter = new EngineeringValueFormatter( "S2" );
~ Paul H
(7,348 Views)
Thanks, did it this way.
(7,340 Views)
