wpf graph: axis label formatting
How do I configure the graph to show only first and last label on the axis? I think it's somehow should be done by modifying RangeLabeledDivisions.Mode property...
                     <ni:AxisDouble x:Name="horizontalAxis1" Orientation="Horizontal" Label="X" BaselineStroke="{x:Null}">
                        <ni:AxisDouble.MinorDivisions>
                            <ni:RangeDivisions TickVisibility="Hidden" />
                        </ni:AxisDouble.MinorDivisions>
                        <ni:AxisDouble.MajorGridLines>
                            <ni:GridLines Stroke="{StaticResource GraphGridLinesColorBrush}" />
                        </ni:AxisDouble.MajorGridLines>
                        <ni:AxisDouble.MajorDivisions>
                        <ni:RangeLabeledDivisions TickVisibility="Hidden">
                            <ni:RangeLabeledDivisions.LabelPresenter>
                                <ni:GeneralValueFormatter Format="0.00" />
                            </ni:RangeLabeledDivisions.LabelPresenter>
                        </ni:RangeLabeledDivisions>
                    </ni:AxisDouble.MajorDivisions>
                </ni:AxisDouble>
(7,709 Views)
Accepted by eugenem
You can set the Mode on the MajorDivisions to a Count mode of two:
        <ni:RangeLabeledDivisions Mode="Count: 2" TickVisibility="Hidden">
This will show just the minimum and maximum divisions for the range.
~ Paul H
(7,701 Views)
thanks!
How do I make left label aligned left at 0 and right label aligned right at max? Now they both are aligned center.
(7,697 Views)
Have a look at this question.
~ Paul H
(7,694 Views)
got it, works!
(7,691 Views)
Another clarification: when I use count:2, all gridlines are also gone. How can I get both gridlines and 2 labels?
(7,681 Views)
The grid lines are tied to the major divisions shown by the axis. To show the divisions without the labels, you can leave Mode set to Auto and use the opacity technique from the hide labels question, switching the logic so the opacity is changed for the non-extreme labels.
~ Paul H
(7,676 Views)
