wpf graph dot line type not working
When I set line type to dot, dash-dot, dash-dot-dot, I don't see any dots, only dashes. Graph is in vector mode. Solid lines are also working of course.
(8,748 Views)
Accepted by topic author eugenem
I was not able to reproduce the issue. Here is the test code I used:
    XAML
    <ni:Graph x:Name="graph" RenderMode="Vector">
        <ni:Graph.DefaultPlotRenderers>
            <ni:LinePlotRenderer /> <!-- Solid -->
            <ni:LinePlotRenderer StrokeDashArray="4 4" /> <!-- Dash -->
            <ni:LinePlotRenderer StrokeDashArray="1 4" /> <!-- Dot -->
            <ni:LinePlotRenderer StrokeDashArray="4 4 1 4" /> <!-- Dash Dot -->
            <ni:LinePlotRenderer StrokeDashArray="4 4 1 4 1 4" /> <!-- Dash Dot Dot -->
        </ni:Graph.DefaultPlotRenderers>
    </ni:Graph>
    Code
        graph.DataSource = Enumerable.Range( 0, 5 ).Select( plot =>
            Enumerable.Range( 0, 201 )
                .Select( i => plot + Math.Sin( i * Math.PI / 200 ) )
                .ToArray( )
        ).ToArray( );
When I run, it looks like this:
Graph Line Styles
~ Paul H
(8,741 Views)
  // Summary:
  //     Implements a set of predefined System.Windows.Media.DashStyle objects.
  public static class DashStyles
    // Summary:
    //     Gets a System.Windows.Media.DashStyle with a System.Windows.Media.DashStyle.Dashes
    //     property equal to 2,2.
    // Returns:
    //     A dash sequence of 2,2, which describes a sequence composed of a dash that
    //     is twice as long as the pen System.Windows.Media.Pen.Thickness followed by
    //     a space that is twice as long as the System.Windows.Media.Pen.Thickness.
    public static DashStyle Dash { get; }
    // Summary:
    //     property equal to 2,2,0,2.
    // Returns:
    //     A dash sequence of 2,2,0,2.
    public static DashStyle DashDot { get; }
    // Summary:
    //     property equal to 2,2,0,2,0,2.
    // Returns:
    //     A dash sequence of 2,2,0,2,0,2.
    public static DashStyle DashDotDot { get; }
    // Summary:
    //     property equal to 0,2.
    // Returns:
    //     A dash sequence of 0,2.
    public static DashStyle Dot { get; }
These are standard definitions and they aren't working. Yours do work though. Thanks!
(8,730 Views)
From what I can tell, DashStyle is only used to initialize a Pen, whereas other objects like shapes expose separate StrokeDashArray and StrokeDashOffset properties instead. If you want to use the pre-defined styles, you can select the Dashes property on the appropriate instance:
    <Rectangle Stroke="Black"
               StrokeThickness="5"
               StrokeDashCap="Square"
               StrokeDashArray="{Binding Dashes, Source={x:Static DashStyles.DashDot}}" />
~ Paul H
(8,723 Views)
I took Dashes of course
note that numbers are different, I think this is the problem
(8,721 Views)
I think which numbers you need depends on the stroke dash cap being used: Flat requires a non-zero size, while other values can use a zero size and still show a line.
~ Paul H
(8,719 Views)
