wpf square graph axes
I need to make ScatterGraph with perfectly square axes, which also should fill its container. It will display the unit circle (radius 1, positioned at 0), so non-square axes are very annoying.
What I do now, is something li this, but it doesn't make perfectly square axes.
private void graphWrapper_SizeChanged(object sender, SizeChangedEventArgs e)
 if (squareArea)
  int size = (int)Math.Max(0, Math.Min(graphWrapper.ActualWidth, graphWrapper.ActualHeight) - 10);
  graph.Width = size + 35;
  graph.Height = size;
  graph.HorizontalAlignment = System.Windows.HorizontalAlignment.Left;
(5,935 Views)
Accepted by eugenem
You can use the following SizeChanged event handler on a graph to maintain a square plot area:
    private void OnGraphSizeChanged( object sender, SizeChangedEventArgs e ) {
        Thickness margin = graph.Margin;
        Size plotAreaSize = graph.GetPlotAreaSize( );
        Size current = new Size(
            plotAreaSize.Width + margin.Left + margin.Right,
            plotAreaSize.Height + margin.Top + margin.Bottom );
        double ideal = Math.Floor( Math.Min( current.Width, current.Height ) );
        graph.Margin = new Thickness {
            Right = Math.Floor( current.Width - ideal ),
            Bottom = Math.Floor( current.Height - ideal )
~ Paul H
(5,921 Views)
