Measurement Studio for VB6
6229 + Visual Basic 6
Running a USB 6229, programming with VB6, because I am a strict newby with LV
Following is a code snippet attached to a Command Button:
cmdReadCH0_Click()
Dim Value As Double
    'Create task
    DAQmxErrChk DAQmxCreateTask("", Handle1)
    Task1Flag = True
    DAQmxErrChk DAQmxCreateAIVoltageChan(Handle1, "Dev1/ai0:1", "", DAQmx_Val_InputTermCfg_Diff, 0, 0.2, DAQmx_Val_VoltageUnits2_Volts, "")
    'DAQmxErrChk DAQmxReadAnalogF64(Handle1, 1, 10, DAQmx_Val_GroupByChannel, Value, 1, 1, 1)
    DAQmxErrChk DAQmxReadAnalogF64(Handle1, 1, 10, DAQmx_Val_GroupByScanNumber, Value, 1, 1, " ")
    lblCh1.Caption = CStr(Value)
    If Task1Flag Then
        DAQmxClearTask Handle1
        Task1Flag = False
    End If
End Sub
I am setting up channel 0 as differential, with a range of 0 to 200 millivolts, 10 second timeout, simply to read and display (for now).
I get RunTime Error '-200492(fffcf0d4)'  Measurements: Reserved Parameter must be NULL.
I am obviously not defining the parameters in the function call properly, but which ones?
Thanx for the guidance.
(7,286 Views)
Hi JEY2,
         This KB discusses the solution to your error.  Please let me know if you're still having problems with this.  Have a great day!
(7,272 Views)
Yes, that KB took care of the problem.  I had to increase the size of the buffer to get a good read, but that was simple.
What is the significance of the ":1" in the address "Dev1/ai0:1"?
Thanks again for the help.
JEY
(7,248 Views)
Glad that helped!  The significance of the ":1" is that "Dev1/ai0:1" means channels 0 through 1 (so you're using 2 channels).  If you only wanted to use one channel you could simply specify "Dev1/ai0".  Have a good one!
(7,238 Views)
