Measurement Studio for VB6
cwAIPoint versus cwAI?
If I simply need to sample 3 or 4 different channels (NRSE and Diff) using a E-Series DAQ card, at a sampling rate of approximately once every second, am I better to use the cwAIPoint control, or the cwAI control (set to a short burst and then average (say 10 samples at 1kHz))?
And why?
Chris
(6,413 Views)
Hi MadMax,
I would recommend using the cwAI control and averaging the data, since the averaged value will be more accurate than a single point, however if you are measuring a signal that does not change quickly, it would probably be a bit easier to implement the AI point method. Let me know if you have any other questions!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(6,398 Views)
