Measurement Studio for VB6
Error -200077
I am getting an error -200077 when I run my example code in VB 6.0. I am using USB 6008 for my application (analog output). I have seen the following link that gives explanation for the error that I am getting.
 http://digital.ni.com/public.nsf/allkb/0332E1EE7081091D862570360030C9F4?OpenDocument
But, the instructions given in the above link did not help me.
I used comma instead of the decimal point, but still the example did not work.
Earlier I had put -10 to 10V as the range and then I changed it to0 to 5V.
Still it did not help.
Can someone please suggest me how I can rectify this error. If you have any other sample code in VB 6.0 for analog output generation from USB 6008, I kindly request you to share the same.
Thanks in advance.
Herok
(6,968 Views)
Any inputs or suggestions on the above query?
(6,961 Views)
