Measurement Studio for VB6
Analogue Acquisition inn VB6
Im a rookie and im trying to acquire 4 voltages from sensors and save the data in VB6.
What is the procedure/code for starting the card acquiring and taking the 4 voltage values?
(6,774 Views)
I'm assuming that you have a NI DAQ card.  There are some VB examples that should've been installed with NI-DAQmx by default (if you installed DAQmx after installing VB6).  Take a look at the example code in your National Instruments directory (eg. C:\Program Files\National Instruments\NI-DAQ\Examples\Visual Basic 6.0\Analog In\Measure Voltage\Acq-Int Clk).
Let me know if you have any questions.
Way S.
NI-UK Applications Engineer
(6,765 Views)
