Measurement Studio for VB6
CWPlot3D.Baseplot and FillToBase property
Hi all
I tried to use the baseplot property with my 3D mesh plot in order to fill the space between two surfaces. But I always get the error message "property or method non valid for the object". I use mesurement studio 6 - VB6. Can anyone explain to how to use these properties ?
Thanks in advance
Beta66
(8,108 Views)
Hi Beta66,
I'd like to help you but in order to dig down the problme alittle deeper I need to know wich version of component works you are using.
Thanks a lot.
Regards.
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(8,093 Views)
Hi FiloP
thanks for replay
my componentworks
3dgraphcontrol version is 7.0.0 (344)
ciao
beta66
(8,083 Views)
FilOp
I finally realized that baseplot and filltobase properties affect only 2D graph objects. In such a case i hardly understand the reason why they are included in the cw3dgrph.chm help file.
However, can you suggest my a way to fill up volume limitetd by two (mesh built) surfaces ? I was wondering if there is a chance using parametric surfaces, but i did not succeded so far.
thanks
beta66
(8,061 Views)
Filop
I'm still waiting for your valuable suggestions.
Beta66
(8,043 Views)
