Measurement Studio for VB6
Can't find Led indicator
HI,
I have installed Measurement studio 8.5 to work with my VB6.  I can't find the led indicator.  In which activeX should I find it?   Did I fail to install something?
Rafi
(7,268 Views)
Accepted by topic author Rafi2003
Hi Rafi2003,
The LED is part of National Instruments CW UI.  You will see the CW button (toggle switch) in your toolbox when this is a selected component.  You can place this control on your form and right click to bring up the properties.  In the property pages dialog box that appears, you will see the LED indicator located under the style tab.
Cheers,
Kelly R.
(7,241 Views)
Great, Thanks!
Rafi
(7,234 Views)
