Measurement Studio for VB6
WLS-9205 does not connect
I have an ethernet WLS-9205.  It was connecting yesterday in Measurement and Automation but today it will not.
No changes were made to the PC.  We can PING the device from the command prompt.  We can connect to the device when we use another PC.  So it makes me think there is something wrong it the drivers installed on the failing PC.
Windows Firewall is turned off.
Any ideas of what we can try????
Thanks, Jay Boden
(6,243 Views)
Hey Jboden,
Are you not able to connect through wifi or through direct cabling or both? If we try direct cabling and setting up the system again, do things work then? You can see it in one computer,but no longer in this one so we need to narrow down what might have changed. We could try a repair on the driver, but it seems strang if nothing has changed on the PC, that the driver that was working yesterday would fail overnight.
Thanks again,
Nick
(6,225 Views)
