Measurement Studio for VB6
Can't use flexmotion vb ex's due to problem retriving error description.
Im having problems using the examples supplied with the motion control
(version
6.1.2). My problem is essentially the same as a problem on your discussion
forum. The problem is under the heading "Retrieve error description from
PCI-7334 board with VB". A solution is given but when I replace the
function
prototypes in the file FLEXMOTN.BAS, it generates an error
"-70022(NIMC_functionSupportError)". Any help you could provide would be
greatly appreciated.
Thanks very much,
Paul.
Software Details: Visual Basic version N/A
NI Hardware : Motion Control device MID-7604
Driver Version : 6.1.2
Operating System: Windows XP
(5,645 Views)
I recommend that you post this question to the Motion Control and Motor Drives forum. This forum is monitored by Measurement Studio users. The Visual Basic interface that you are using is not related to Measurement Studio.
(5,636 Views)
