Measurement Studio for VB6
How to serial byte array in VB?
Now I do some protocol about the RS485 communication. My communication was piont(Master PC) to multi-point(Microcontroller). In order to decrease bytes during communication. I defined some of bits as command, some bits as address in one byte. So I have encode and decode procedure. When the data was returned by slaver station, I got ASCII data. I don't want to get the ASCII data. I want to receive binary data directly. For example, I received "A", its real value should be 65(b01000001). This sample, I set return as string. Whether the return as byte array of serial component in VB can get 65? Because I have no sample about this one. I only know how to use "return as string". Anybody can help me and give me one simple sample?? Thank you very much.
Message 1 of 8
(9,930 Views)
Hi
I'm not quite sure I understand what you are trying to do. Here is an example Serial Instrument Control in Visual Basic. Let me know if this is what you are looking for. If you still have questions repost. Have a great day!
JenK
Message 2 of 8
(9,913 Views)
I can't open your website??
Message 3 of 8
(9,902 Views)
I've attached the program below. Here is the description:
This program demonstrates how to perform serial instrument communication using Visual Basic 6.0. The example was written to communicate with an NI Instrument Simulator. Communicating with other instruments should be possible by modifying the example which uses 9600 baud, 8 data bits, no parity and hardware handshaking.
Message 4 of 8
(9,888 Views)
Thank you! Jenk! I got your sample. But I know that that is MSComm component. Actually, I wanted to know NI's serials component. As I know MSComm's input data can be set to Binary. But I'am not sure the function of NI's Serial component.
Message 5 of 8
(9,858 Views)
I'm not sure what you mean by "I wanted to know NI's serials component. As I know MSComm's input data can be set to Binary. But I'am not sure the function of NI's Serial component." Can you expand a little bit on that? Thanks!
JenK
Message 6 of 8
(9,832 Views)
NI's serial component was in the measurement studio. If you install the measurement studion in your computer, you can open Visual Basic then add National Instructments CW Instr 6.0. After that, you can see serial and GPIB components in your component chart. Serial component was almost the same to mscomm. It can be used easier on project. Now I have settle the issue of byte array. I have changed the development tool to C++ builder.
Message 7 of 8
(9,801 Views)
you maybe change HEX to ASCII in your MCU
such as:
ASM SUB
HASC: MOV B,A ;暂存待转换的单字节十六进制数
LCALL HAS1 ;转换低四位
XCH A,B ;存放低四位的ASCII码
SWAP A ;准备转换高四位
HAS1: ANL A,#0FH ;将累加器的低四位转换成ASCII码
ADD A,#90H
DA A
ADDC A,#40H
DA A
RET
ASCII TO HEX
ASM SUB
ASCH: CLR C
SUBB A,#30H
JNB ACC.4,ASH1
SUBB A,#7
ASH1: RET
VB conversion function
ASC("A") return to ASCII "65"
HEX(65) return to HEX : "01000001"
Message Edited by riversand on 04-10-2005 12:04 PM
Message 8 of 8
(9,683 Views)
