Measurement Studio for VB6
Cannot connect to RIO using C#
Trying to make a C# NI VISA windows application by following the instructions from "Getting Started with Measurement Studio" Support for Visual Studio 2010. After choosing my "RIO0::INSTR" as instrument, at add step i chose query and parse, as written in the tutorial but after runing the command *idn? gives me the error : "The given session or object reference does not support this operation.   VISA Status code : bfff0067"
I would like to continue my project but i cannot establish a communication with the module. I verified from "Measurement & automation explorer" and it says there that my RIO0 device is working properly.
I would appreciate if you could give me an advice.
Thanks.
(6,871 Views)
What is your rio device? How is it connected? Serial, Ethernet, or GPIB? The National Instruments Instrument I/O Assistant organizes instrument communication for a serial, Ethernet, or GPIB instrument into ordered steps.
(6,856 Views)
Through this module i wold like to connect to my digital circuit
https://www.ni.com/en-us/support/model.pxi-7811.html
PXI-7811R
I have the cable a connector block and i would like to give digital signals to my circuit which i would like to test.
(6,853 Views)
Zoozo,
Take a look at this tutorial:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5DNCAY&l=en-US
You will need LabVIEW FPGA to program the FPGA on the PXI 7811R. But the pins already have custom code associated with them. The C interface (FPGA Interface C API Generator) takes a bitfile and pulls out items like FIFOs and Read Write controls. You can talk to yout R series card, but won't be able to program it without the FPGA module. And you will also need LabVIEW because there is no scan engine on the R series card. Hope this helps!
Jordan
(6,831 Views)
