Measurement Studio for VB6
Integrate area under graph between 2 cursors using Measurement studio.
Hello; Are you able to assis with sample VB6 code on how to integrate the area under a curve between 2 cursors using VB6. I can easily do this in Labview but need advice on how to do it using measurement studio and VB6.
Thanks.
Dayaa
(8,333 Views)
Hi Dayaa,
Have you tried looking in your National Instruments\MeasurementStudio\VB\Samples folder for example code?  If you cannot find anything that you can use, I suggest you look for the same integration function that you used in LabVIEW in your VB6 object browser and go from there. You might also want to post your VI you created in LabVIEW so we can see exactly what you're trying to do.
Way S.
NI UK Applications Engineer
(8,323 Views)
Hey, you mentioned you can easily integrate area under graph between 2 cursors - can you please share with me as to how? I would like to integrate the area - but my graph has multiple plots.
(6,183 Views)
