Measurement Studio for VB6
Cwstat1.ExpFit returns wrong results
  The following routine using Cw1stat.expfit returns wrong results. Any Idea?
Cem
Public Sub Fit(x as variant,y as variant)
  Dim i As Variant, amp As Variant, decay As Variant, mse As Variant
  Dim  z As Variant
 CWStat1.ExpFit x, y, z, amp, decay, mse
     For i = 0 To UBound(x)
        Debug.Print i, x(i), y(i), z(i)
    Debug.Print amp, decay
End Sub
Data
x=   10, 14, 17, 20, 23, 28, 31
y= 162, 269.5, 245, 245, 550,1372, 2025
Wrong Results
 10    162         127.532
 14    269.5        207.63
 17    245         299.270
 20    245         431.346
 23    550         621.711
 28    1372        1143.383
 31    2025        1647.98
amp=37.706       decay= 0.1218
Correct Results
10  162  80.9
14  269.5  149.7
17  245  237.6
20  245  377
23  550  598.3
28  1372  1291.8
31  2025  2050
amp=17.3455  decay=    0.1539
(7,288 Views)
Girit, I have plotted your solution graphically.
Results correspond to “Wrong Results”.
I think the solution is correct.
Why you consider, what the received results are wrong?
Yours respectfully,
Vladimir Sotin
(7,277 Views)
Vladimir,
    I tested the results against Matlab and SigmaStat. Both produced results exactly the same and with better mse. If you plot what I call the correct results you will see the difference. Thank you anyhow.
Cem
(7,272 Views)
Hi Girit,
I tested out that CWStat method and it worked just as you mentioned in your post. The results that were returned are correct based upon our algorithm. Perhaps those other languages are using different algorithms. If you launch the Measurement Studio Help (Start >> Programs >>  National Instruments >> Measurement Studio >> Help >> Measurement Studio Reference) and then type in CWStat in the Index tab, you can go the a page that displays all the different methods for that ActiveX control. Select the ExpFit method and you will see the algorithm we use.
Hope this helps!
Best Regards,
Jonathan N.
(7,259 Views)
Girit, I have plotted the correct results graphically.
Really, the plot looks better. It better represents the data points.
All the best,
Vladimir Sotin
(7,250 Views)
