02-25-2006 07:12 AM
The device we are using is the NI USB-9162. We are using a non-standard PC, so are trying to avoid anything that will require a card, since the expansion possibilities are limited to a couple low profile PCI slots. (Traditional PCI cards will not work).
The idea of using an active x control is interesting, but we have had a lot of issues re-registering dlls when people have tried to build them in the past. Are you referring to building a DLL or something else? I'm using class modules and creating objects off of them, but have not had the chance to experiment with building active x objects in VB6. Could someone upload a small sample of a control using a timeout event to set a flag?
Is it possible to have an active X contol run its timer independently of the main program execution (asynchronously) in VB6?
Thanks for the advice. I'm going to run out and redefine my class module to setup the task when initialized and see how it affects the performance.
Tom
02-25-2006 04:35 PM
02-26-2006 02:24 PM
Hi tbhin-
The USB-9162 is just a carrier for the actual DAQ device you are using. Can you please let me know which module (i.e. cRIO-92xx) is being used in conjunction with the carrier? BTW, David- thanks for your excellent input and insight.
02-26-2006 04:11 PM
The actual models are: 9421 and 9472, sorry about that. Thanks for the great inputs. I modified the routine to keep the tasks open instead of closing them and reseting the device each time and the read times are down well under a millisecond.
I'll have to take a look at the OCXs, I developed an application using one timer for each sensor, each sensor of course is one digital input. I have the timer interval set to 1 and the response time is acceptable for my application. (By the way, I found that I needed to put a "Do Events" in each timer. The result without was that the first two or three timers loaded got all the CPU attention and the others were pretty much ignored. By using Do Events, they all shared pretty much equally.
The class modules all work well together, but the thing runs into trouble when I try to incorporate it with other mainline code. I noticed that the timer events are sometimes getting hit, other times ignored when the main application is doing nothing. Maybe the OCX approach will help here. I'll start a new thread with that one.
02-26-2006 05:13 PM
11-28-2006 07:41 PM
I had the same problem using Delphi, because the value 1 for "DAQmx_Val_SynchronousEventCallbacks" I got from the .h header is not accepted by the callback registering function and using 0, the default option, the callback function does not return the stack pointer correctly (crashing the application) if I declare the callback function as "cdecl".
What is the numeric value of the DAQmx_Val_SynchronousEventCallbacks option?
The manuals and the .h file set the callback function as "cdecl". But using Delphi this does not work anymore as worked in the reliable and good Legacy NiDaq dlls I have used for more than 6 years ! Sigh... I am getting really upset with this new mx drivers ...
If I cannot change the thread calling the callback event function and the "cdecl" does not work as well... what to do? To forget 6 years of software development using NI cards?
Well, I used "stdcall" for the callback function and it worked. But I do not know why...
Lavio
		11-29-2006
		05:21 PM
 - last edited on
		03-07-2025
		06:51 PM
 by
			Content Cleaner
Hi Merlin-3,
If you are experiencing error -50251, please consult the following KnowledgeBase, it has great information on using DAQmx with Delphi.
KnowledgeBase: Can I Make NI-DAQmx Calls From Borland Delphi?
I hope this helps!
Erik
