Measurement Studio for VB6
DataSocket Server Manager cannot save new setting.
I have run DataSocket Server Manager and tried changing the settting (Creators) to allow everyhost to write and create new items.Then saved my new setting. I have restarted DataSocket Server. When I run DataSocket Server Manager again, it open a default setting not the one I saved.
(3,321 Views)
I am not able to reproduce this issue with the version of DataSocket that I have on my machine. What version of the DataSocket Server Manager are you running? You can see the version if you click on About DataSocket Server Manager from the Help menu. Also, DataSocket Server Manager saves its settings in the cwdssini.dss file in the DataSocket installation folder. The problem you're describing could happen if this file is read-only, so check attributes of this file.
- Elton
(3,321 Views)
