Measurement Studio for VB6
NI DMM via DLL from C++
I've now given up on trying to use the NIDMM DLL from VB.NET and am delving
into doing it in C++. As far as I can tell, this code should build and run
#include "stdafx.h"
#using
#include
#include "nidmm.h"
using namespace System;
// This is the entry point for this application
int _tmain(void)
// TODO: Please replace the sample code below with your own.
ViChar resourceName[256] = "DAQ::1::INSTR";
ViSession vi = VI_NULL;
ViBoolean idQuery = VI_TRUE;
ViBoolean reset = VI_TRUE;
ViStatus error = VI_SUCCESS;
Console::WriteLine("Hello World");
niDMM_init(resourceName, idQuery, reset, &vi);
niDMM_close(vi);
return 0;
However, on building I get this ou
tput;
Linking...
DMM2.obj : error LNK2001: unresolved external symbol "long __stdcall
niDMM_close(unsigned long)" (?niDMM_close@@$$J14YGJK@Z)
niDMM_init(char *,unsigned short,unsigned short,unsigned long *)"
(?niDMM_init@@$$J216YGJPADGGPAK@Z)
Debug/DMM2.exe : fatal error LNK1120: 2 unresolved externals
I have added the include and lib directories to the search paths and can
build the examples. I have distilled one of the examples down until it is
not very different from the above, and I can start working with that, but I
would like to know why the example works and mine doesn't. Any suggestions?
Dr. Craig Graham, Software Engineer
Advanced Analysis and Integration Limited, UK. http://www.aail.co.uk/
(3,982 Views)
Ah. Project Properties needs to be fiddled with as well as the paths in
Tools->Options. Doesn't say that in the documentation. For reference;
Linker->General->Additional Library Directories, add the VXIpnp lib
directory
Linker->Input->Additional Dependencies, add nidmm_32.lib.
"Craig Graham" wrote in message
news:3f24eb20@newsgroups....
delving
> #include "stdafx.h"
> #using
> #include
> #include "nidmm.h"
> int _tmain(void)
> niDMM_close(vi);
> return 0;
> However, on building I get this output;
> Linking...
I
suggestions?
(3,982 Views)
