Hi!
I need to see if DS is updated in LV 7.1. There is a simple method for this in older versions of LV. Using the VI DataSocket Data Updated.vi where a Boolean true is returned if DS indicates an update.
What is the equivalent in LV 7.1?
Is it using the polymorphic VI or using property node?
Idriz
Idriz "Minnet" Zogaj, M.Sc. Engineering Physics
Memory Profesional
direct: +46 (0) - 734 32 00 10
http://www.zogaj.se
