Measurement Studio for VB6
Error appears while switching visibile property of annotations
When I try to set the visibilety property of a cwgraph-annotation in code, and try to run the program, runtime error 458 appears "Variable uses an automation type not used in Visual Basic".
This has  happened directly after an installation of the measurement studio package.
An installation on a different computer seemed to solve this problem, but I need it to be working on a particular computer I use. It's just a normal PC-Laptop using windows XP.
It seems to be some sort of installation problem. It only happend once before, and that was also on a laptop. It couldn't be solved at that time either.
I hope anyone could help me. Thanks in advance.
(6,197 Views)
What is the version of the CWGraph being used? Try downloading the latest update of the ActiveX User interface controls and see if the problem still happens.
I hope this helps
Bilal Durrani
NI
(6,190 Views)
The installation of the updates have helped and solved the problem!
Thank you!
Michiel Koot
(6,186 Views)
