Measurement Studio for VB6
Events in cwgraph Control array
I have created a control array of cwgraph at run time.
Now all the properties are accesible but I am unable to fire events (with index) on cwgraph....
please help.
(3,260 Views)
When the sub for the event in a control array gets called it will get passed the index of the control for which it will be called.
The simplest way to handle the events then is to use a case structure which selects off of the index parameter. The following example should illustrate this.
-Amaury R.
(3,260 Views)
