Measurement Studio for VB6
FPGA vector signal transceiver
NEED HELP ASAP  .   please advice , see included
The litepoint IQ 2015 has the RF xmt and rcv  COMBINED on one output port.
This is how we want our NI  unit  to operate.
NI  FPGA Vector Signal Transceiver (which is broken up into 2 RF ports).
I think the reason they did this is so you could use 2 80 GHz bandwith VST's
in parallel to get the 160 MHz 802.11AC full traffic.  In that case it
requires multiple in, multiple out.  But most of my applications, I need to
run Single in, Single out..
So I would like to combine the RF In, and RF out just for convenience.
Do you have a RF  combiner for the NI  FPGA Vector Signal Transceiver unit 's two  outputs ?
Can  NI  FPGA Vector Signal Transceiver  software multiplex   2 signals
in parallel , 160 MHz 802.11AC full traffic and WiFI / Btoooth 2.5 GHz full traffic
within a  2 80 GHz bandwith  ?
Thank you
Travis Lee
e mail : Leetr@us.panasonic.com
(7,074 Views)
Thanks for your post. I have a couple of clarifying questions for you.
1) Which VST are you using?
2) It sounds like you would like 80 + 80 MHz on a single VST, 2 ins and 2 outs, but you also mentioned RF In + RF Out, so that is somewhat confusing. Can you please clarify what you would like in the end?
3) If you could provide an overview of your application, that would be great.
Thanks!
Kevin S
Applications Engineer
(7,001 Views)
